TwinTurbo.NET: Nissan 300ZX forum - Re: Cylinder Compression results
ttz'in (norcal)
on August 08, 2015 at 2:40 AM
posted by mboston
on August 07, 2015 at 10:28 PM
If you haven't noticed any unusual smoking, it may not be piston rings. If 2, 4, & 6, are the low cylinders it may have something to do with the machining / valve work done on that head at rebuild.
Leak-down test should narrow it.
mboston
22:28:50 08/07/15
Re: Cylinder Compression results -
ttz'in (norcal)
02:40:12 08/08/15
also shot of oil in the cylinderes and retest >>
ZUL8TR
04:01:58 08/08/15
Re: also shot of oil in the cylinderes and retest >>
mboston
10:40:06 08/08/15
Re: Re: Cylinder Compression results
mboston
10:08:09 08/08/15
^2nd, leak down test it (n/m)
Stanky
03:43:11 08/08/15
Do a Leak Down Test..
Cjw3
08:56:06 08/08/15
Re: Do a Leak Down Test..
mboston
10:40:39 08/08/15
Leak Down Test Results
mboston
20:46:46 08/08/15
I think the next step is to look at the belt
Cjw3
09:09:35 08/09/15
Re: I think the next step is to look at the belt
mboston
19:02:40 08/09/15
First Off.. Look and see if the Marks Line up..
Cjw3
21:07:12 08/09/15
